Return to Index
Read Responses
An inclinometer
In Response To:
how dumb is this idea?
An inclinometer or(clinometer) like the one in the link could be used to cover the hole.
Steve
BRASS CLINOMETER
Mount a nice piece of wood over it.
Wood with a timer on it.
Agree with Genec.... wood
Is there anything else you would like to mount there?
How about a fixed port?
Oh, 2" hole. Sorry.
Just call it a peep hole, then.
Pick up some plush toys, get some bean bags and turn it into a carnival attraction.
Two thoughts
Friend launched a 39' custom.
Glass it up and then gelcoat the entire side of the aft end of the house...
An inclinometer
If you're so inclined....
inclinometer.....hmmmm
check the Water Witch specs
2" hole is also standard for VDO gauges
Good idea, 'high water alarm'
