Return to Index
Read Responses
Look what they recommend for main halyards
In Response To:
If you look, Wichard recommends the for spinnaker halyards.
See link. I don't like them.
http://www.wichard.com/menu-Halyard_shackle-0202090000000000-ME.html
Main Halyard Shackle
I'd go with the keypin
I wouldn't use the quick realease shacke on the main?
Been using one on this boat since 2001
I have had the fail
No different than a screw shackle
Why don't the recommend them for the application you are suggesting, Larry?
why? Would have to ask the product manager
Larry, those a "specialty" shackles
Also the length of the trigger release shackle may affect the hoist of the sail.
It's mot the 'static' load that is is the issue
If you go to
Thanks for everyone's input
I have seen the Wichard 81434 bend and deform...
If you don't reef in strong winds, the forces go way up
How about a knot instead of a splice ?
Halyard Knots
Knots
I suspect it is not as strong
I doubt strength will be a problem
I think he is talking knot to the shackle vice splice
Knot on shackel...
Dyneema soft shackles
I had to laugh...
Yup - no need for a whisker pole
Agree with the knot.
Buntline Hitch is my choice also. Never had a problem
