In that case
I think you definitely want the interior temp to be at least 10-degrees above freezing, and 45 is a good setting. If it's zero outside, the in-wall temperature will be somewhere between interior and zero. How much variance depends on a lot of things, insulation being a big one, but the differential between interior temp and exterior temp is the other big one.
