Torlon is really good stuff
Oh, I just looked it up on McMaster Carr and it is not cheap. But it is a very good bearing material with very good wear characteristics, low friction, low moisture absorption and low creep. If you can afford $310 for a 1/4" sheet it would be a great way to go. You can compare materials at http://www.mcmaster.com/#8574KAC
