... on that load bearing washer. And that weight probably isn't all that much with the boat in the water and a buoyant rudder. With the boat out of water, which it is for 6-8 months a year, there would be considerably more load, but not ever moving. Thanks for the suggestions, that Teflon Delrin from MMC is what I had in mind ! Cheers, John
