Return to Index
Read Responses
Tides Marine - 3.5" diameter Shaft -
In Response To:
For your Tartan 40, that should be an Edson Steering system?
http://www.ebay.com/itm/like/190872378324?lpid=82
-- a boat buck plus shipping.
A Rudder Stop Collar question ...
Torlon is really good stuff
Whoa ... the Gucci Delrin rod or sheet is 1/10th that ! Thanks, cheers, John
john, can you take picture with a cell phone or digital camera?
Thanks, not sure I understand your suggestions ...
COOL, wow ... Thanks ! Can't believe you found that on ebay ! cheers, John
Answers ...
You could drill out the Tides Marine...
Thanks Brian ... I was hoping no one would say that ...
Another thought...
Thanks Brian ... good idea, I think those guys are great for custom work ...
Do you have an access panel from the quarter birth?
No. See "Answers" above, next to last parag ...
If the Delrin is really being "plolished" or "ground" by the load, it will wear over time
Delrin AF is probably as good a choice as any...
Yes, correct ... just the weight of the Rudder ...
John, you can also get split collars from McMaster...
Thanks for that DDW ...
