...where I will be doing all the modifications to add the step. The step, the hinge and the latch will all be on this side, hidden when this face is flipped around and in place and the door is closed.
As you can see the sill of the door area is already wider, but I will add more material at the bottom of the sill to add compression strength to the whole area.
