When unplugging....
When unplugging from shore power ALWAYS turn off AC loads or preferably the AC main breaker on board. Not doing so can cause arcing on the shore plug/socket which can make it less safe than it already is. If you are unplugging and the breaker trips that means loads are on, not good.... Turn off the ships AC before unplugging or re-plugging....
