Did you tape the core to the fid?
I haven't spliced for a while so I'm a bit rusty. A bit of electrical tape helps keep the core in the fid. It does take quite a bit of force to get the core buried so I make a loop big enough to put my foot in and then start working the cover up from there. Keeping some tension on the core may help to reduce its diameter but I don't usually do this.
