Also the copper gaskets on the banjo.
There are 2 for each fitting. If you cannot get replacements you can anneal and reuse them. To anneal the copper heat it red hot and drop into cold water. I know that is the opposite for the technique for annealing steel but that's what the technical data says. Smooth the surfaces with fine sandpaper (at least 600 grit) then reinstall.
