Return to Index
Read Responses
I'll try that.
In Response To:
Nope. Just bring the hose to the bench grinder and cut away the sheath...carefully!
Anyone cut and re-use the banjo fittings on their diesel?
I have done it before...
Yes, two ways to go, have done both
Use fuel/heat rated hose
Also the copper gaskets on the banjo.
Thanks for all this. How did you cut the fitting clamp off?
I have used a bench grinder to..
Did you mean angle grinder?
I'll try that.
Actually I didn't the leak was at the gasket.
On copper, you can just heat.
I sort of thought so too.
In my stumbling around I went to a hydraulics shop.
Thanks. My son told me that, too.
48 dollars for 6 copper washers!
