Return to Index
Read Responses
It looks as though you'd need two of these... for an A/B system
In Response To:
I recently installed Nasa Marine's Clipper BM-1 Compact
New Old Boat refurb. Battery monitor recommendations.
Not giving advise, just asking...
Yes, each one only handles a single battery bank.
I have the same BM-1 unit
Sounds like I really need to add a starter battery.
Battery setups
A/B Switch
i considered doing sometyhing like that.
Correct, sort of.....
Gottcha
battery monitor
Your Link 20 might be best replaced by finding a "used on" if you use it to control the Heart/Xantrex unit.
The biggest problme with the...
We had the 2000R (Heart version) -- it worked fine until we replaced it with the Mastervolt and sent it to others to use
Xantrex still makes a basic remote...
What about the XBM?
The XBM
monitor
You might like this one....
Fascinating.. Balmar Smartgauge... thanks!
