Return to Index
Read Responses
Yep- but sometimes and some hoses needs longer than 30 seconds
In Response To:
soften the hose...
Much safer than a heat gun though
For the new sanitation system...
soften the hose...
YES
Have you seen Forespar's 1.5" Marelon Vented Loops ...
Is that a new hose?
Trident 105
Shields 105 a/k/a "Poly X"
You can't soften Shields 105..
So you end up using unbarbed fittings for one of your largest thru hulls?
