Practical Sailor rated it "Best Choice," and it is priced accordingly. It is wire reinforced, and doesn't respond to heat as the unreinforced hoses do. It does fit pretty easily onto unbarbed fittings, which I am double-clamping. Thanks for the hint on the Forespar vented loop. I will try it.
