Iron + salt water = corrosion
Add movement and flex at the keel-hull attachment, bumps and scrapes when the boat grounds, freeze-thaw of winter storage, and normal expansion-contraction. Net result- cracks and gaps. Water gets underneath the coating, and it's all downhill.
Crappy stuff to work with too.
