The owner's manual from Catalina said in no uncertain terms that the boat was designed to be used in fresh water only. The iron swing keel and retracting mechanism was NOT to be used in brackish or salt water. The related corrosion of the lifting mechanism cold cause catastrophic failure with loss of the boat.
