Return to Index
Read Responses
Interestingly, 3M marine silicone
In Response To:
I you use silicon -- make sure its marine silicone (no acid)!
... smells like it contains acetic acid. Check it out -- it smells like vinegar.
What do you use for stainless steel screws in aluminum?
I mostly use Tel-Gel, and sometimes Duralac. Cheers, John
2nd vote for Tef-Gel
Tefgel or silicone sealant
+1 on that!!!!
I[f]
There others, other than Boat Life -- but I prefer Lifeseal to silicone
Tef Gel is good
One caveat about Tefgel....
Right Brian
Good point on backing out. We have had no
Teflon thread tape.
I've found that allows it back-out screws, but it's not a good corrosion blocker. The "tape" tears and then...
Bronze Powder Anti Sieze
