Return to Index
Read Responses
Tef Gel is good
In Response To:
What do you use for stainless steel screws in aluminum?
We have taken screws out after ten years, on deck
Our boat is aluminum, so we use Tef Gel a lot
http://McCubbin.ca
I mostly use Tel-Gel, and sometimes Duralac. Cheers, John
2nd vote for Tef-Gel
Tefgel or silicone sealant
I you use silicon -- make sure its marine silicone (no acid)!
+1 on that!!!!
Interestingly, 3M marine silicone
I[f]
There others, other than Boat Life -- but I prefer Lifeseal to silicone
Tef Gel is good
One caveat about Tefgel....
Right Brian
Good point on backing out. We have had no
Teflon thread tape.
I've found that allows it back-out screws, but it's not a good corrosion blocker. The "tape" tears and then...
Bronze Powder Anti Sieze
