Thinking out of the box a bit
How about cutting discs out of cutting board material, sanding the edges round and smooth? If you use a hole saw to cut them you can just cut a channel to slip them over your shroud wire, and screw a tab of metal or plastic on the side to form a "gate" to keep it in place. If you attach above the spreader it could move up but not down, and you could put some tape above to keep it from climbing in high wind.
