Return to Index
Read Responses
Happy to help
. I have probably 100 of these on my boat now.
In Response To:
What a fabulous solution. SOLD!
http://anomalyengineering.com
And now a technical question
I'd say risky..balsa does give them much to bit into too soft
Jeez Les, that doesn't sound like a good idea
Too bad about the new headliner.
OK, I guess I knew that would be
Thinking about it..
Less, Have you ever used "Barrel Bolts"?
What I do in this situation is make tapped inserts....
Very nice!
That's a good way to do it but aren't you
Yes, both methods do...
Wow, I didn't know the bond would be that strong. Every
You can reuse the insert threads a number of times, but not as durable as stainless.
Strength of insert not an issue.
The area is similar to a backing washer....
Happy to help
Me too!
a quick point with epoxy. .If the fastener is just slightly misaligned, you can heat
"real heavy guests"...how heavy, Les?
I'm sorry to have to say that
I would think that's dangerous.
It's certainly a safety factor
