Return to Index
Read Responses
I've sort of tried that
In Response To:
VOM Test
and didn't get any meaningful results. I'll try again and be a bit more meticulous.
Taste test
VOM Test
If you want a really good reading build a jig
You could put drops of water on glass and see what kind of rings they leave
Maybe I'll get one of these
Of course Amazon has them
Be sure to read the comments on this...
My bilge is now dry
Just taste it...
Ptooey!
If the bilge is that clear, you really should be okay with the taste test. If it's not, then it's time for ... ;^))))
