Return to Index
Read Responses
As usual, many great ideas from the Board … THANKS everyone ! Cheers, John
In Response To:
Another Varnish question ...
I can only think of one other option, and you probably won't like it,...
Yup oval head screws with trim rings look OK, however...
I like the idea of exposed screws... Someday you are going to have to remove those fiddles and...
Removing properly installed bungs is easy as long as they haven't been glued in with epoxy or such
Yes, old bungs all came out easily … They were probably varnished in, no glue, no glue residue whe
good- I had a cabin rebuild for someone where the bungs had been epoxied in. Had to over drill and
Excellent idea Todd … thanks … However ...
Thanks Tom ...
Re: Another Varnish question ... I've fought thi question myself several times. No matter
I like the matching corian fiddles glued on idea. Or, brass and/or bronze screw heads look.....
Good idea..bronze screws would almost disappear in teak.
and line up the slots in the slotted screws instead of having them every which way. Looks nice.
