Are you storing in a very windy area?
What does your boatyard recommend?
Do they store most boats mast up?
I don't recall the boat you bought but you should be able to replace the light mast up.
Take a good look at the mast step and the base of the mast for any signs of corrosion. If there is any indication of a problem pull the mast.
