Return to Index
Read Responses
My brain was apparently inneutral.....
In Response To:
You would need a three ohm 50 watt resistor...
A 5 ohm 50 watt resistor would also work fine.
Battery question
Pretty strange that they were registering 13.1 volts dry and not lately charged.
Something's not right..
Re: Battery question
Thanks
Thanks...
You could load test them, but...
X2
Beyond posts below, another suggestion
answers
You can lose battery fluid from engine charging systems, bad cells, or shore power chargers.
Re: You can lose battery fluid from engine charging systems, bad cells, or shore power chargers.
I figure shore power cooks most batteries.
You're supposed to check them?
Give 'er a try.
Probably a little diffence in battery quality here
Re: Probably a little diffence in battery quality here
