Return to Index
Read Responses
You're supposed to check them?
In Response To:
I figure shore power cooks most batteries.
Maybe I should take a look at mine.
Battery question
Pretty strange that they were registering 13.1 volts dry and not lately charged.
Something's not right..
Re: Battery question
Thanks
Thanks...
You could load test them, but...
X2
You would need a three ohm 50 watt resistor...
My brain was apparently inneutral.....
Beyond posts below, another suggestion
answers
You can lose battery fluid from engine charging systems, bad cells, or shore power chargers.
Re: You can lose battery fluid from engine charging systems, bad cells, or shore power chargers.
Give 'er a try.
Probably a little diffence in battery quality here
Re: Probably a little diffence in battery quality here
