Return to Index
Read Responses
short pendant would be an easy fix to try.
In Response To:
Thought about this
With any length pendant, will you increase fouling/tangling the sheet as the fiddle block lays down?
main sheet rigging opinions please
Should work
PS -- Dyneema
A lanyard may work
I'd start with the lanyad/pendant or whatever you cal it. Easy, cheap to start.
Had same problem,
Re: main sheet rigging opinions please
Re: main sheet rigging opinions please . . . I hate cam cleats . . .
Long ago, crewed on a 50 ft on deck schooner. Taught me FAST to never let go a loaded line without
Is there a reversed cam cleat set up? Pull up to release?
Thought about this
Could run it thru a lenght of PVC pipe to help it stand up
I found a photo
Hmmm?
answers
If it were my boat I'd add the traveler
Traveler
How about a 'swivel cam cleat base'?
Have you consulted a rigger?
none within 100 miles
Well then you should be posting photos here and we will got to work on it!
I hear you, my mainsheet is driving me crazy.
