Re: I found the diagram I need
In Response To: I found the diagram I need ()
Sadly, no nice exploded parts views like they have for there rudder bearings. The bearing is probably a snug sliding fit on the shaft, and needs some persuasion to get started. Something holds the shaft from pulling out, could be a split ring behind the bearing. If you have a bearing puller that can apply carefully controlled force to the housing, that's where I would start.
