Return to Index
Read Responses
Is that flush when underway or is there a shallow rain catcher area? Deceptive in pic.
In Response To:
Back to a new cockpit: It took me a day to fit this old manhole into the cockpit sole.
So anyway to use the part you cut out...
I've got to cut new 3/4" thick decking to fit flush. Not right now,...
Too bad, would have been nice to "match the grain."
Believe it or not, it is handy. There's a pretty large space below.
Ouch, seacocks hidden down there...
As regards side locker access to below........
Good thing you got help
The access in many areas of a boat is very limited. Especially older designs.
My engine access is wide open
Wow, that's nice. In the old days, engines and access were given little thought. Not a good idea,...
Re: I've got to cut new 3/4" thick decking to fit flush. Not right now,...
I ended some shorts in that circle, Al. Might have been a good idea.
All flush. The lid/cover is recessed for 3/4" thick decking, laid inside the pan.
Ah, of course! That tells it all. What will you use to hold the decking in place?
The old pieces were screwed in place - from below. I'm thinking adhesive.
That'd be what I'd do.
Then,...done!
Sure, then you can blame it on me if it lets go.
