Return to Index
Read Responses
Not much different
In Response To:
This is an approach that will keep your engine room dry, not challenge your impeller, and let
The only difference in my approach is the "bucket" is smaller. Same in principle.
Cracked block?
Well, first...
Did the engine ever overheat?
Never overheated that I know of
HOSE to INTAKE???
Nothing like that
I guess, but you may mess-up your impeller?
Not much different
With the 5 gallon bucket in the cockpit, you can walk away after you have it set-up.
Paranoia. You do not have a cracked block.
That's what I'm hoping
Agree with Tom
I don't know about overflow tank level
Interesting you mention the head gasket
High oil and low antifreeze
