Return to Index
Read Responses
I don't know about overflow tank level
In Response To:
Agree with Tom
I don't have any reference levels marked or noted, so I can't say if it's up or down.
Cracked block?
Well, first...
Did the engine ever overheat?
Never overheated that I know of
HOSE to INTAKE???
Nothing like that
I guess, but you may mess-up your impeller?
This is an approach that will keep your engine room dry, not challenge your impeller, and let
Not much different
With the 5 gallon bucket in the cockpit, you can walk away after you have it set-up.
Paranoia. You do not have a cracked block.
That's what I'm hoping
Agree with Tom
Interesting you mention the head gasket
High oil and low antifreeze
