down my 3000 watt generator unless I adjust the input. Your battery is only drawing only 6 amps when discharged seems strange. AGM's advantage is fast charging so they will take almost everything you can deliver. I would look at your battery and it's ability to supply the needed current and it's recovery to normal. Sum'em ain't right.
