Re: Half the cockpit well is full of well lashed / I have 2 diesel and
1 dinghy gas lasted to a SS rack on the port side deck of Brendon. I also have a 13 gallon auxiliary tank in the engine room. I have a built in Racor filter / pump arrangement to pump from the jugs into the main tanks so no lifting going on here. I've also been known to lash a 40 gallon plastic drum into the cockpit for the bash up the "Baja" for the bash. I have two of them in storage that I don't know what to do with. They seem to be needed for only one way, up the coast. The're in SD if anyone needs one.
