Return to Index
Read Responses
You can get hooks that go where that awful steel bolt is.... (nm)
In Response To:
DQOD - Slab reefing the mainsail. (pic)
I don't know
Nope not at all.
The horns of a dilemma...or the dilemma of the horns?
We have the rams' horns; work fine. (link)
Same same. Always worked nicely for me.
Just run the line through the D ring.
Buy ball-bearing blocks and attach them to the D-rings. Run your lines through them and your systems will work better.
You can remove the D-rings and add GoƮot blocks IN the cringle ...
That looks like an interesting solution! (nm)
And, you can use it as a cunningham. (nm) (link)
That's the way mine works. Just install
I use a rams horn
Have your sailmaker add a velcro closed....
Ha.. That's just the next thing I was thinking.
Better than horns
Similar solution....
