Return to Index
Read Responses
Well I can definately answer the last question (pic)
In Response To:
Now into the intricacies SSB anttena grounds...
soon as I get back from the fridge ;)
First, I suppose I should learn to spell "antenna" (nm)
The dictionary police are out! (grin) (nm) (pic)
probably, If you're trying to do it fast and cheap then ground it to the engine. (nm)
FWIW here's how my last and my present boat are set up
I found this ICOM manual extremely useful when I installed my marine SSB (link)
The ICOM manual is great. I suggest anyone doing SSB on a boat should take a look...
The one thing you do not want to do is connect the RF ground to anything that is connected to your DC ground...
By accident I had my SSB ground connected to my engine for almost 5 years
Wouldn't the water in the shaft log hole be a partial . . . (pic)
After some serious thinking and drinking ...
Aluminum and copper together might be a bad (link)
Did some (unintentional) destructive testing this summer
The aluminum tape I'm using is actually insulated
Looking forward to the report, Ron
