Return to Index
Read Responses
probably, If you're trying to do it fast and cheap then ground it to the engine. (nm)
In Response To:
Now into the intricacies SSB anttena grounds...
First, I suppose I should learn to spell "antenna" (nm)
The dictionary police are out! (grin) (nm) (pic)
Well I can definately answer the last question (pic)
FWIW here's how my last and my present boat are set up
I found this ICOM manual extremely useful when I installed my marine SSB (link)
The ICOM manual is great. I suggest anyone doing SSB on a boat should take a look...
The one thing you do not want to do is connect the RF ground to anything that is connected to your DC ground...
By accident I had my SSB ground connected to my engine for almost 5 years
Wouldn't the water in the shaft log hole be a partial . . . (pic)
After some serious thinking and drinking ...
Aluminum and copper together might be a bad (link)
Did some (unintentional) destructive testing this summer
The aluminum tape I'm using is actually insulated
Looking forward to the report, Ron
