its easy enough to find fiberglass tube, but if you use it you must make very sure that the line does not rub anywhere on it. If it does, it will wear away the resin and start picking up fiberglass - not good for your lines or your hands. I used SS tube, but sealing it on the ends required some custom machined fittings and I am still having some issues with keeping it sealed.
