Return to Index
Read Responses
If your stanchions have guides (i.e., the holes are lined through the stanchion)
In Response To:
Had non coated made 6 yrs ago and no problem with abrasion at stanchions.
You won't get abrassions there -- or if you're gentle ;^)
inspecting and replacing lifelines
By all means use uncoated wire
Exactly like Max says ...
We stripped the coating off.
Well
I used 2" pieces of reinforced tubing from Lowes that fit snugly in the stanchion holes (nm)
Did my lowers 2 years ago.
thanks all (NM) (nm)
Voice in dissent - I like vinyl coated
I agree -- think egg slicer anaology... Synthetic might be better
Uppers I use Amsteel, lowers use bare wire. (nm)
Same here. I just replaced mine with new vinyl coated
People..you have to PERFORM MAINTENANCE..coated/uncoated
Interesting ... When I Bought Indigo ...
Uncoated
