Return to Index
Read Responses
Interesting idea. I have some 3m preservation tape 4811.
In Response To:
Wrap it
That should do the trick.
DQOTD -- painted mast and moisture problems?
What is the mast painted with? (link)
Don't know. I assume it's some flavor of 2-part sprayed-on finish. (nm)
I'm not sure about the paint lifting
David - Where/how else do you use that sill gasket?
I use it anywhere there might be chafe.
Wrap it
Well...
Deck area isn't an issue. The boat is folded. (pic)
Nice Looking Sabre :-) (nm)
with training hulls (nm)
fergot the ;D (nm)
