Return to Index
Read Responses
I don't think you can blame the wire ties here.
In Response To:
Yes thread so corroded that the pin just slipped out
Lack of inspection and replacement was the problem.
rich
If you keep your boat on a mooring these tips might keep it off the rocks
That wasn't a hardware failure..it was an operator failure..
It was neglect!
Monel is more corrosion resistant than stainless particularly in the absence of oxygen
I use a triple bridle all the time on my home mooring
Tight seizing wire...
pool noodles work better
Never tie up to the top of a mooring ball...
Never? If the chain comes through to the top it's OK
Here in Onset, only the chain-through-the-ball is allowed.
Yeah, and if you attach to the swivel below the ball
What actually happened to that hardware ?
It looks as though that shackle has lost a third of it's section where it met the swivel, due to wear.
