http://www.dhmo.org/facts.html
* Death due to accidental inhalation of DHMO, even in small quantities.
* Prolonged exposure to solid DHMO causes severe tissue damage.
* Excessive ingestion produces a number of unpleasant though not typically life-threatening side-effects.
* DHMO is a major component of acid rain.
* Gaseous DHMO can cause severe burns.
* Contributes to soil erosion.
* Leads to corrosion and oxidation of many metals.
* Contamination of electrical systems often causes short-circuits.
* Exposure decreases effectiveness of automobile brakes.
* Found in biopsies of pre-cancerous tumors and lesions.
* Given to vicious dogs involved in recent deadly attacks.
* Often associated with killer cyclones in the U.S. Midwest and elsewhere, and in hurricanes including deadly storms in Florida, New Orleans and other areas of the southeastern U.S.
* Thermal variations in DHMO are a suspected contributor to the El Nino weather effect.
Should I be concerned about Dihydrogen Monoxide?
Yes, you should be concerned about DHMO! Although the U.S. Government and the Centers for Disease Control (CDC) do not classify Dihydrogen Monoxide as a toxic or carcinogenic substance (as it does with better known chemicals such as hydrochloric acid and benzene), DHMO is a constituent of many known toxic substances, diseases and disease-causing agents, environmental hazards and can even be lethal to humans in quantities as small as a thimbleful.
Research conducted by award-winning U.S. scientist Nathan Zohner concluded that roughly 86 percent of the population supports a ban on dihydrogen monoxide. Although his results are preliminary, Zohner believes people need to pay closer attention to the information presented to them regarding Dihydrogen Monoxide. He adds that if more people knew the truth about DHMO then studies like the one he conducted would not be necessary.
A similar study conducted by U.S. researchers Patrick K. McCluskey and Matthew Kulick also found that nearly 90 percent of the citizens participating in their study were willing to sign a petition to support an outright ban on the use of Dihydrogen Monoxide in the United States.
