I'm curious...
Since you were there and the most danger may have been to move: What did you do? Did you tie off to another line then fix the pin? Did you tie off to the mas or masthead and then fix the pin? Did you go down gingerly, go up on another halyard and then fix the pin?
Inquiring minds want to know.
Fair Winds
