second the bebi owl. it's amazingly bright with almost no battery drain.
In Response To: Get a Bebi Owl instead ()
i leave mine on 24/7 when i'm moored or anchored out. didn't even bother getting the one with the light sensing switch. i figured that entire display uses less power in 24 hours then my old anchor light used in one hour.
i hang mine from the topping lift about halfway up the mast. brightest anchor light in the field.
