Jerry you should look again. There is no similarity at all
In Response To: actually, Kong has two gadgets ()
.... between the Kong Nautilus and the Anchor Witch.
Kong Nautilus is like adding a sliding shank to the anchor, which IMHO is a stupid idea. I wouldn't even use a slotted or sliding shank on a lunch hook. Take a look at the anchor witch video and you'll see it's an entirely different approach: It's clipping on a trip line AFTER you're stuck.
