improper maintenance is not likely to sink your house. Sure you can have leaks or electrical issues, just the same as you can on a boat, but with a house, while you are still fighting the elements, is not likely to ever sink.
Yes, it probably is far more expensive to maintain both a house and a boat than to cruise full time. Likely it is more expensive to have just a house than a cruising boat.
