Return to Index
Read Responses
You might say...modus ponens ;^)
In Response To:
Not that stuff. The SuperLube grease with PTFE is the right stuff.
Peggie ... DQOFD ....
SuperLube is what I use
This is the info on the SuperLube
Hmmm - -I was using that on things like shaft coupling screws
I don't care what language you curse in
SupeLube makes a whole bunch of different products
I used the same stuff Larry does
The right stuff doesn't come in a can, it's a thick grease in a tube
Thick grease in can with same labeling ???
Does it have the NSF certification?
Yes; says NSF listed H1
Since Leaving the Country ...
Peggy, the SuperLube product that I'm using is
The Super Lube grease is definitely thicker than their Anti-Corrosion Gel
What Larry & SG show is what Peggy will recommend. Healthy squirt in the pump housing. Cheers, John
PTFE = teflon
My Superlube Grease Experiences
Suprising? Been using for years, never an issue on Raritan or Impellers for engines?
Another new material to worry about
So what do you use for a lubricant on your HF head?
Back to silicone grease
From Don Casey's How to
Don Casey likes doing it the hard way...
But don't leave the vinegar sitting in the pump long-term -- it curls rubber parts.
It shouldn't be left in the pump at all...which is why I specify "flush through the system"
I once made the unfortunate error
unfortunate errors
Thanks for sharing :^) Way too much info :^)))))
Man, you must have been pooped after that ordeal!
And the sad thing is...
not to be too contrary, but
Have not found that to be true...
repacing head discharge hoses
Only two reasons to replace sanitation hose...
I just went through this
distilled vinegar
Most distilled white vinegar doesn't start out as fermented vinegar...
Recommend Dow Corning #111
