The Super Lube grease is definitely thicker than their Anti-Corrosion Gel
I have a tube of both. I use the grease on winches and rubber parts, and the folding prop. I use the anti-corrosion gel on the shaft coupling and other non-stainless parts to protect from rust. They seem to get rusty anyway.
