Peggy, the SuperLube product that I'm using is
"Super Lube Anti-Corrosion Gel has superior synthetic dielectric compound specifically formulated to provide better protection than typical grease. It has excellent resistance to saltwater and most detergents. Contains PTFE, provides improved anti-wear properties, is waterproof, not washed away by acids or alkalis, and resists temperatures to 750 degrees F. The SYNCOLON-TM (PTFE) particles in Super Lube's unique patented formula are held in constant suspension ensuring they will always be evenly applied to the lubricated surface as needed. "
It comes in a vaiety of sizes of containers: two or three tubes, a can (or cans), and lube-gun cartriges. It's a PTFE based product. It has NO oil in it and its NSF rated, won't harm real rubber products and not degrading in salt?
It's pretty thick?
