If your knotmeter isnt mounted exactly on the boat's centerline you will get dissimilar readings from one tack to the other. This is due to the different/differing flow patterns across the hull, the depth/immersion of the paddlewheel on different tacks, etc. etc. .... all hydrodynamic 'anomalies' and flow patterns acting on the paddle wheel.
