Return to Index
Read Responses
The rate in MD is currently about the same. In the recent past, marine diesel was actually MORE. Bit of price gouging?
In Response To:
The road tax paid on it....
Is there any difference between
"marine diesel" = additives here
Valvtec is different, but you can add your own additives
Idle mention on gasoline here: found two stations nearby with non ethanol premium for boats.
ValvTect gasoline
So if you added your own biocide and
Steve, what's a fuel transfer system for us never owned a diesel boat group?
Well, I use a lot of fuel going up the outside of Baja
Wow! Thanks for the description.
Probably not
The obvious difference is the color of the fuel...
The color is only a marker.
A fried ran his VW Rabbit on home heating oil
