Return to Index
Read Responses
Steve, what's a fuel transfer system for us never owned a diesel boat group?
In Response To:
So if you added your own biocide and
Is there any difference between
The road tax paid on it....
The rate in MD is currently about the same. In the recent past, marine diesel was actually MORE. Bit of price gouging?
"marine diesel" = additives here
Valvtec is different, but you can add your own additives
Idle mention on gasoline here: found two stations nearby with non ethanol premium for boats.
ValvTect gasoline
Well, I use a lot of fuel going up the outside of Baja
Wow! Thanks for the description.
Probably not
The obvious difference is the color of the fuel...
The color is only a marker.
A fried ran his VW Rabbit on home heating oil
